horn
Old Jul 14, 2006 | 09:49 PM
invaderzim1915's Avatar
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
horn
well some one ripped off the air bag and horn cover on my steering wheel i need to know what contacts to connect to make the horn work to see what the next step will need to be thanks
Old Jul 17, 2006 | 09:48 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Bummer! Did they steal just the air bag and leave the wheel and horn harness?
Old Jul 18, 2006 | 01:48 PM
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
no it is all gone it only has the one metle strip that is up and down on the right side the rest is gone
Old Jul 18, 2006 | 01:49 PM
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
no it is all gone it only has the one metle strip that is up and down on the right side the rest is gone if any one has a wireing diagram i and fix the problem it is just i can't find a wirring diagram
Old Jul 18, 2006 | 03:30 PM
Wadebryant's Avatar
The horn harness assembly under the air bag is pretty simple, if that's what your missing (in addition to the air bag). Two wires with two spring loaded contact assembly points. You could order a new harness for the steering wheel from your GM dealer or pick one up real cheap at a wrecking yard. I'd start with the later as you might also score a airbag too.
As for a wiring diagram, check the repair manual. It'll show you the circuit path but probably wont give instructions for replacement of the horn harness in your steering wheel. If you pull the missing parts from a donar at the wrecking yard you'll see how simple it really is. Good luck.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
