Headlight activation issue
Old Jul 16, 2006 | 07:36 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
My buddy's 87 GTA has a problem where his headlights delay coming up sometimes once the switch is hit. The motors are freshly repaired thanks to the TDS kit, but he was also having this issue before I repaired them (and now after as well). What happens is he hits the switch, the lights come on, but nothing else happens, and then suddenly the motors activate and they pop right up. Sometimes this can take as long as a minute or two.
I'm thinking relay or the switch itself, and wondering which is the most likley culprit.
Old Jul 16, 2006 | 07:51 PM
89pontiac400's Avatar
Car: 1989 Pontiac trans-am
Engine: building a 400
Headlights
I
Old Jul 16, 2006 | 08:00 PM
Headlights
I've had the same problems with mine. I'd like to hear from someone that knows a lot about the headlights. They a cool but a pian when they don't work. A friend of mine told me to try wiggiling the switch after turning them on and it seams to work. I'm gona try to repalce it and see if it helps. I'm also gona try repalcing the relay I read in a magazine that they can cause the problem also.
Old Jul 16, 2006 | 08:21 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
mine are the opposite.. mine are lazy on the way down.... I'd like to hear solutions as well...
Old Jul 18, 2006 | 09:08 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Bump
Old Jul 18, 2006 | 09:19 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I'd replace the headlight control module. If you're getting a used one remember the 1987-89 used a different one than the Model Year 1990-92 (actually through 2002). The module slips into a bracket on the firewall between the brake master cylinder and windshield wiper motor.
Lon
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
