Turn light issue
Old Jul 18, 2006 | 09:15 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Turn light issue
left turn light blinks extremely slow at a stop when the amps are being pulled by the fans and headlight, yet the right one blinks perfectly fine. Sometimes it even stops blinking alltogether and just stays solid...
Also with the headlight on, my passenger side turn light does not work, it only blinks when I put the signal on
Old Jul 19, 2006 | 06:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LEFTY LOOSEY
Most likely cause is one of the
4 left signal lamps is burned out.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Old Jul 20, 2006 | 09:42 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
neither of my marker/ turn lights work on my fenders... could that be it?
Old Jul 20, 2006 | 11:19 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
It could. The rate of flash depends partly on how much current is being pulled through it. If it is not loaded up properly, it won't flash as quickly. I'm pretty sure it operates on the same principle as a christmas light flasher... a strip of metal changes shape as it heats up due to the current flowing through it. When it reaches a cetain temperature, it springs away from the contacts and the circuit is incomplete. It cools, returning to the original shape, and the circuit is complete again..... So you can see how having a smaller load would effect the rate at which the metal heats up. Somebody correct me im wrong.
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
