Is this distributor too strong?
Old Jul 24, 2006 | 11:00 AM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
I found this really cheap, brand new distributor that puts out 65,000 volts. This is the link to the page: eBay Motors: CHEVY HEI DISTRIBUTOR 65K V SUPER COIL 350 400 383 RED (item 250010996338 end time Jul-28-06 22:49:34 PDT)
Is this too much power for my 350 engine? Also can I attach the MSD 6AL ignition box to this later on or will I have to get a billet distributor?
Old Jul 24, 2006 | 11:44 AM
Vader's Avatar
An ignition system will only generate the level of voltage necessary to jump the gap of the plugs. A system which MAY be able to develop a peak of 65KV will more likely operate at 20-30KV driving around the street or strip, just like a stock ignition. The need for higher voltage arises when cylinder pressures increase well above what a stock engine will create in normal driving.
Old Jul 24, 2006 | 12:58 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
That makes sense. Would this distributor work with a MSD 6AL?
Old Jul 27, 2006 | 07:16 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I don't see why not
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
