Gas gauge problems
Old Jul 25, 2006 | 09:42 PM
cdacda13's Avatar
Car: 1992 Camaro
Engine: 5.0L TBI
Gas gauge problems
Ever since I bought my 90 Firebird, the gas gauge hasn't worked. Its stuck on E. The needle never moves either.
I go to test the wires out to see if thats the problem (I really hope it is) but I don't know what I should be testing for. Volts? OHMs?
Anyone else have this problem? Any tips on how to fix it?
Thank You
Old Jul 25, 2006 | 10:14 PM
Johns1989irocz's Avatar
Car: 1989 Iroc
Engine: 5.7L 350 TPI
i had this problem start on my 89 iroc after i changed the fuel pump, if somebody replaced the fuel pump on your car, they may have bent the float arm, also, check to make sure the wiring harness up in front of the tank is not damaged and is connected.
hope this might help you figure out the problem
Old Jul 26, 2006 | 12:57 PM
cdacda13's Avatar
Car: 1992 Camaro
Engine: 5.0L TBI
I pretty sure that the first owner never replaced the fuel pump.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
BurlyChev
Aug 16, 2015 09:08 PM
