What does it mean to ground a wire
Old Aug 6, 2006 | 08:19 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
What does it mean to ground a wire, and how is it done?
Old Aug 6, 2006 | 11:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The wire is connected to the body or engine or some other grounded metal part of the car.
Old Aug 8, 2006 | 09:18 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
ground = negitive current (-) usually black coated wires are grounds
Old Aug 8, 2006 | 09:46 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
AC or DC have both a positive and negative in order for man made components to work. A ground is basically the negative terminal which completes a circuit. In a vehicle, everything operates on 12 volts which consists of a positive and a negative. Like other have stated a good ground is either the frame, or any piece of metal that is properly grounded via the negative battery terminal.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
djmarch
Aug 19, 2015 12:07 PM
