Anyone know what this is?
Old Aug 8, 2006 | 05:03 PM
teal_RS_305's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI
Axle/Gears: 2.73's
Its right above the hump and i'm thinking it has something to do with the gas tank? Nothing is connected on the other side.
Old Aug 8, 2006 | 05:21 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Now that there is what is commonly referred to as your henway!
Old Aug 8, 2006 | 05:29 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
That is for the guy that cut that great big *** hole so he could replace the fuel pump/sender.You remove it go and find him wrap it around his kneck and just befor he passes out turn him around ,slap the crap out of him ,and tell him that if he ever comes near your car again you will repair the hole with his head! If it was you who cut the hole have your buddy do it!!
Just kidding I would probably do the same thing if I had to,but as far as what that is I'm not sure.I know you said nothing plugs into it on the other side/but what does it look like...is there a plug/ is there nothing?
Good luck,
Mike
Old Aug 8, 2006 | 05:40 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Good luck,
Mike
ROLMFOA
Old Aug 8, 2006 | 05:42 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
I took a skip thru my Chiltons and found nothing in the electrical / fuel / body interior sections.
Good luck,
Mike
Old Aug 8, 2006 | 06:17 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
all very funny stuff but seriously it is for the fuel pump power and fuel gauge wires. there should be a connector going to the fuel sender on the other side. Mike
Old Aug 8, 2006 | 06:56 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by 83z28camaro
all very funny stuff. Mike
I can't wait until April 1st again
Old Aug 8, 2006 | 08:40 PM
Car: 91 Camaro RS
Engine: 5.0L TBI
Axle/Gears: 2.73's
There is a plug on the other side but I was just saying there is nothing plugged into it. The hole is for the bottom of a fuel cell. This is a friends car and he couldnt find anything in chiltons either so he asked to me post it and see what it was. Thanks
Old Aug 8, 2006 | 08:58 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
exactlly, thats what its for.... purple is power for the fuel pump power... i think the other 2 are grey and black, gray is for the fuel level indicator, and black is ground i believe? CMIIW
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Teal, if you are referring to the wire in that picture, it is indeed for the fuel sending unit located in the top of the fuel tank. BTW, are those some big cracks that I see radiating out from that hole in the frame there?
Old Aug 8, 2006 | 10:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
No, that's where the cutter of the metal realized the hard lines run from the sender to the frame rail and had to cut even more to get the FP out.
*edit.. unless your talking about what appears to be a massive crack by the shock mount ?
Old Aug 8, 2006 | 10:15 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well I suppose it's a good thing the idiot didn't blow him or her self up cutting into metal over a gas tank
Old Aug 8, 2006 | 10:45 PM
deadbird's Avatar
Engine: TPI 305/ v6
A wrong cut here or there is easily possible. The tank is extremely close to the shell sheetmetal (w/in ½"-ish).
The 'fuel pump door' idea really isn't that bad of a concept except for the hard line connections are not made anywhere close to the sender.
Most who do this cut the lines then clamp high pressure fuel hose back in place.
I wouldn't be opposed to this approach if the 'saginaw' (push connect w/o-ring) flare wasn't so expensive to reproduce.
It would be t--s to yank up the carpet, open a hatch door, yank the pump, replace & reverse process instead of the drop everything approach.
I've changed 4 to date (not all in one car)... and.. still sucks.
Just my opinoin though...
