Question between 1988 350 maf harness and 1989 350 maf harness
Old Aug 8, 2006 | 10:39 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Are the engine harnesses from a 1988 Trans am with a 350 and a 1989 Formula 350 going to be the same? Im thinking of sending the trans am harness out to get converted to speed density, and I want to be able to just plug it into my formula and have everything work.
I've read of problems with the C100 and C207 connectors being different between maf/sd camaros/firebirds.
Im hoping that this trans am harness will bypass any headaches. If someone has schematics, that would be awesome too. Thanks!
Old Aug 8, 2006 | 01:46 PM
Car: 89 formula 350
heeeelp lol
Old Aug 8, 2006 | 10:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I could be wrong but, I though S/D started in 89 ?
If so, than yes, they are different. If still MAF, should be the same.
The coolling fan wiring from 87 to 88 is the only thing I know of different.
VATS was not in 88 either (or at least the 88 TPI I put in a friends truck). I dont think that affects the engine harness (in the bay) though. Probably does on the interior side with the signal wire to the ECM (kills the injectors IIRC) and the started disable relay.
Old Aug 9, 2006 | 07:45 AM
Car: 89 formula 350
SD started in 90.
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
