A/C wiring question
Old Aug 7, 2006 | 04:52 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
A/C wiring question
My a/c does not work, here is the situation. When I turn the a/c on the compressor does not come on. First, should I have power at the blade connector at the compressor. With the motor running, blade connector disconnected and a/c turned on in the car, no power on the test light. I dont know the freon level and I am not sure which fuse to check. I looked at the heater/ac fuse, 25amp and it is good. I understand about the low and high pressure switches but I think I should have power regardless? Thanks in advance for getting me started.
Old Aug 7, 2006 | 06:39 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Htr/ac fuse is the fuse for the clutch. If you have low enough freon or a bad low or high pressure switch you will have no power to the clutch. Do you have a v8 or v6. Check for power going in and out of the low pressure switch on the accumulator and then at the high pressure switch. Mike
Old Aug 7, 2006 | 06:47 PM
Notplayn's Avatar
Thanks for the info Mike,
Its a v8 350- 89 GTA
Does the vehicle need to be running when I am checking for power on the switches or just key on?
Old Aug 7, 2006 | 08:10 PM
Vader's Avatar
Key on would be sufficient.
Old Aug 7, 2006 | 09:20 PM
Notplayn's Avatar
I will check the low pressure switch. I noticed that the blade connector
looks melted or at least it got hot. I noticed that there is what looks like a diode wired in on the bottom of the blade connector. Wondering if I might have a problem with the connector on up the trouble tree.
Old Sep 30, 2006 | 05:41 PM
Notplayn's Avatar
Ok, I finally got back around to the a/c problem. I put a jumper wire in the connector for the switch in the accumulator and cut the a/c on. The compressor came on. Now with that said should I try and have the system charged or replace the switch where I jumped it? I took both caps off pressed in the valves and freon came out of both so I know the system is not empty but still could be low....
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
BikeFarm
Aug 11, 2015 11:35 PM
