firebird headlight wiring harness
Old Aug 10, 2006 | 08:02 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
alright i need to find out if the headlight wiring harness from the firewall out to the module/relay and lights is a separately removable harness and not tied into anything else
and also if you swap this harness under the hood from an 86 older one to an 87-up one if you also have to swap the harness inside the car too ?
who has converted from three wire system to two wire system
and was it worth, and would you do it again if you had to ?
trying to make up my mind if i want to replace my broken 82 motors with 82-86 ones, or upgrade to 87-up system
no opinionated info wanted,
only truthful and factual info please thanks
this just tends to be one of these subjects that everyone seems to have a different answer to
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
