Need help with alternator wiring. What do these wires do?
Old Aug 13, 2006 | 12:56 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Can someone tell me where the 3 wires go to from the plug that goes into the back of the alternator and what is their purpose? I have one thick red wire, and 2 blown wires. See attached pic.
This is for an 87 TPI car.
Many thanks,
Robert
Attached Thumbnails Need help with alternator wiring. What do these wires do?-wiring.jpg
Old Aug 13, 2006 | 02:35 PM
jmillar`'s Avatar
Are there any other wires on the alternator? (shouldn't be). Most alternators have a thick red "+ out" wire, and a pair of thinner field wires that have to be energised for the alt to work (should go on with ignition).
I know on the '72 GTO I was rewiring over the weekend the alt and starter shared a heavy wire that seemed to terminate right on the battery. Not sure about that yet but they definitely appear to share a cable. That's your red wire. But normally that's a ring terminal not a plug. The field wires are however normally in a plug. Not sure which is supposed to be positive and I'm not sure (positive? ha) that it matters.
Sorry if I'm misunderstanding something, I tend to feel like I might be insulting you to give you the complete explanation as I would expect someone with a car like that do know that.
Old Aug 13, 2006 | 06:17 PM
skitztikwon's Avatar
there should be a bigger red wire that goes to the starter and one of the other wires go to the starter lookin at the pic you should have a total of 4 wires
and not trying to hijack this thread but how the hell do i post a new thread and would any one know why if you have a good alt and every thing is hooked up why would there not be a charge
Old Aug 15, 2006 | 08:08 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
put a one wire setup on it and be done.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Sep 1, 2015 04:00 PM
Glowsock
Aug 31, 2015 09:01 PM
