battery draw check
Old Aug 13, 2006 | 03:30 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
battery draw check
having a hard time checking 4 a draw. as i understand it, you connect the muttilmeter and set it to mA. then connect the negative wire to the negative terminal and connect the postive to the negative battery side. am i doining something wrong, i keep getting 0.00 ????
Old Aug 13, 2006 | 05:53 PM
highcompression's Avatar
If you aren't used to using a multimeter, you can check for a draw with a 12v test light. Disconnect your positive battery cable, hook one end of the light to the cable and the other end to the battery post(in series). If the light is on while everything is off, you have a current draw. The brighter the light ,the more the draw. You can usually determine what circuit the draw is in by removing one fuse at a time. When the light goes off, you have found the circuit. Be sure your underhood light is not on, as it will show as a current draw. Hope this helps.
Old Aug 14, 2006 | 02:55 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
What range mA are you using? 200 or 2000? Is it set to DC, and not AC?
Did you have the black wire in the COM terminal and the red in the mA/Ohm terminal? It's common to do this wrong.
One possibility is that a fuse in the multimeter is blown, due to too high initial draw (some light being on), or once mistakenly having measured mA across battery voltage.
Another is that there simply is no current draw in the car, i.e. no radio with memory, no clock, no ECM, etc., but surely you have looked for a draw with some lights on..
If you have a 10 or 20A range it is best to start out with this. It usually has it's own separate terminal where the red wire goes. It doesn't take much lights to exeed 2000mA..
deracer
Apr 11, 2016 12:04 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
justin57
Aug 20, 2015 07:05 PM
