msd install
Old Aug 14, 2006 | 07:52 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
msd install
hows it going guys i bought a msd 6al box the other night with all the accompanied components and i'm getting ready to mount it and noticed, theirs not a damn place thats flat in the engine bay with enough room to mount the sob lol.....
So after a good bit of looking around i noticed under neath the upper radiator shroud behind the grille would be a great place for it (less heat more airflow.....) So now i need to install a slightly complicated mount for no metal tools at home unfortunately........
Anyways basically what i'm looking for is where you guys with air conditioning in tact mounted your msd boxes (8in, by 4 in box size btw).
Old Aug 14, 2006 | 10:28 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The MSD box is a rather larger item to plop into the limited space engine bay of a 3rdgen.
Depending on how much you want to get into it, you can go from making a simple sheetmetal bracket to, mounting it insode the cabin, to moving firewall relays to aquire a mount position. It takes a little creativity for certain though.
I went for the move all the wiring route.. (*note* this is not a current picture)
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
