wierd no start problem
Old Aug 27, 2006 | 02:22 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
my car likes to not start when hot, battery is brand new and putting out correct voltage, and the alternator is fine.
when the car is cold it fires up first time every time, after it has been warmed up and shut down the car will not start. has full voltage but i don't get a click from the starter solonoid or anything, just turn the key and nothing. i checked the wire running to the starter and its fine. if i jump start the car when hot it will fire up first go
the car is a 1989 iroc 305 tpi 5spd ac and full power everything. its very consistant, when cold it cranks over when hot it won't, if i let the motor cool down for an hour or two it will start fine, or if i jump it.
any ideas guys? i was thinking a heat soaked starter, but i don't know
Old Aug 27, 2006 | 09:02 AM
j dezzy's Avatar
Car: 87 TA
have you tried opening your choke up a bit more.
Old Aug 27, 2006 | 05:30 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
its fuel injected, don't need to worry about that.
i'm probably gonna rebuild the solonoid and see if that helps
Old Aug 27, 2006 | 06:01 PM
j dezzy's Avatar
Car: 87 TA
it seems like you're not getting anough air.
Old Aug 28, 2006 | 01:18 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
since i'm not getting any engagement from the solonoid, it can't be not enough air, if the motor was cranking over i would agree but its not.
its a faulty solonoid
Old Aug 28, 2006 | 01:26 PM
j dezzy's Avatar
Car: 87 TA
ah. wasn't sure if it was or wasn't cranking.
Old Sep 7, 2006 | 10:59 AM
motorin''s Avatar
Befor you start spending too much time and money on things, it sounds like you might have a bad battery. Have it tested, then troubleshoot from there.
Old Sep 7, 2006 | 09:44 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
im haven the same problem with my car.... if u figure it out or have any ideas let me know pm me or quote this thanks
Old Sep 11, 2006 | 03:14 PM
1989GUNMETALTA's Avatar
i had the same exact problem, would start up in the mornign right away, but if i went to the store and shut it off, it wouldnt start..... i was told by someone on here to replace the starter, and that was exactly what it was.
Old Sep 22, 2006 | 03:31 PM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
I've changed my starter, alternator, and had the battery checked, and I am still having some issue with my car (89 GTA) not starting occassionally. The start enable relay is also only about 2 years old. Any ideas anyone????????????
Old Sep 22, 2006 | 03:49 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I live in the desert
Having a heat-soaked starter is a everyday occurance.
However, After replacing numerous starters thinking that
was the problem, It actually wasnt.
The location of our 3rd Gen starters are tucked up and
from airflow and just sit up there and cook like a turkey..
I expiermented with a JC whitney "Heat wrap" starter
shield and I havent had a problem starting my car after
a long cruise.. even in 110 degree weather
Alot of people just remotely mount there solenoids
inside the engine compartment away from any kind
of heat.
Good luck
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
