urgent! help please! engine wiring
Old Sep 1, 2006 | 08:55 PM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
k.im swapping from f.i v6 right now to small block 350 carb. i need to know what wiring can go.. and what has to stay..i notice the pass. side i disconnected it and went to take it out..but it went back to the drivers side and backinto the car..what the hell can i remove?? i want almost all the wiring outta my engine bay..i deleted ac adn everything..except the blower so i can still use my heat, but i need to know what has to stay for like..the lights and everything, and what can go! and how to get rid of it! i have to have most of this done before tuesday too. thanks guys..please help
Old Sep 1, 2006 | 09:04 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
There is 2 places that wires enter the car. One is on the driverside firewall and the other is through the passenger side under the fender. You can remove every wire that goes in through the passenger side because that is the wires that controled the v6 through the computer that you no longer need. You should still have the wires that go to the starter and the power to the coil. You might need to rewire your alt tho because i think the computor controlled it.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
