Help! How do I wire up an AFS75 O2 Sensor?!
Old Sep 2, 2006 | 01:39 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I am switching to a 4 wire O2, a delco AFS75. I lost the page I bookmarked with the wiring. I searched here but the posts I found were not what I needed
I have 4 wires and I only figured out 2! (I think)
Wire A is Tan ( is this the O2 signal to the ecm?)
Wire B is Purple ( is this the high current ground for the heater?)
( One of the above goes to the original single wire from the stock O2 and the other to ground I think)
Wire C is Black and goes to ground ( Right?)
Wire D is Brown and goes to +12v when the ignition is on (Right?)
I guess I need to know what all 4 wires are just to be safe.
I don't want to hook my meter to it because I read you can damage the sensor by grounding or applying voltage to the output wire and I'm not sure what one that is.
Thanks!
Old Sep 2, 2006 | 01:50 AM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
The purple wire is the sensor wire to the computer if i remember right.I put a three wire on mine so the other two were power and ground for the heater.Hope this helps.
Old Sep 2, 2006 | 11:49 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Thanks I guess I had a few mixed up
Can anyone else verify this?
Old Sep 2, 2006 | 12:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Brown is the heater power.
Black is the heater ground.
Purple is the sensor signal.
Tan is the sensor ground.
Old Sep 2, 2006 | 12:17 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Now off to the bone yard for a 4 wire conector, and whatever else I can stuff into my pockets!
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
