Tach is off.
Old Sep 9, 2006 | 06:33 PM
f_bodyman's Avatar
Car: '91 RS/'69 RS/'01 WS6
Engine: 305 TBI/Undecided/LS1
Transmission: 5-Spd/Undecided/4spdAT
Axle/Gears: 10-Bolts 3.08/3.08/3.73
Tach is off.
I have a 91 RS with a 305 TBI. Recently got the suspicious feeling that my tach was telling me less than the whole truth, so I hooked up a diagnostic computer and was confirmed that it is reading roughly double. Idle at 650 reads nearly 1300 and 1750 reads about 3200. The gauge always works, never cuts out or gets pegged, just is inaccurate. It used to be right on, but no more. Even if it can't be fixed, I'm having trouble finding a replacement. Someone please help.
Old Sep 9, 2006 | 06:39 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
all factory tach's are off by 400-750 rpm rare they will get that high but i have personally seen it!
Old Sep 10, 2006 | 01:00 PM
swap350tbi's Avatar
Car: 91 RS Camaro
Engine: 350 TBI
tach problem
f_bodyman
if you will do a search on tach fix you will find alot of info. on tach repair.
jdmc
swap350tbi
florida
john
Old Sep 10, 2006 | 09:35 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
Mine did that briefly, you might want to make sure that the dist is properly grounded. Mine was missing that middle ground rod off of the coil. Replaced the coil with a new one, and put that rod in, and it went back to it's semi accurate state.
$750 L98
Feb 1, 2025 02:25 PM
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Jlanz55
Sep 29, 2015 08:55 AM
Eric-86sc
Sep 28, 2015 11:37 AM
