NEED HELP Quick.....
Old Sep 10, 2006 | 03:08 PM
91transamGTA's Avatar
Car: 91 Trans Am GTA
Transmission: 5 speed
I have a problem........it sounds like the cold start sensor is sticking wide open when i start the car it sounds like this great sucking noise... when i hold somthing over the hole where the cold start sensor is at it will start up and work but it jerks and bogs and then when i come to a stop is dies and will not work.... I searched and read and could not find anything that worked....could the eprom in the computer be bad i sent it out to a fellow on this site...
Old Sep 10, 2006 | 03:53 PM
i checked the codes code 12 , 14 and 33 came up
Old Sep 10, 2006 | 07:14 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
It sounds to me that you have one big vacuum leak.What cold start sensor are you asking about,the one directly in front of the intake manifold?
Old Sep 11, 2006 | 05:14 AM
yes
yes im talking about the one directly infront of the intake the one that screws right into it..... im not sure if the vacumes are hooked up right is there a diagram out there.....i was told that it is opening and staying open im not sure tho..
Old Sep 11, 2006 | 05:15 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
I will see if I have the Vacuum diagram for you. Just have to wait till I get enough energy to go to my other computer. Mike
Old Sep 11, 2006 | 05:32 PM
alright sounds good thanks
Old Sep 11, 2006 | 06:15 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Here is the vacuum diagram. Mike
File Type: pdf
Old Sep 13, 2006 | 05:33 AM
hey
all the vacumes are hooked up right now and still doin the same thing my mechanic said it is a bad computer its not sending the right signals i ordered a new one yesterday see whats gion to happen
lt1z350
Jul 24, 2013 08:29 PM
PETE
Camaros Wanted
Aug 5, 2007 11:28 AM
mikesiroc
Oct 3, 2001 01:21 PM
