Igntion switch woes.....
Old Sep 11, 2006 | 08:59 PM
'86 350's Avatar
Car: '86 Camaro SC
Well I went to autozone I bought an ignition switch for a manual car the other day since they didn't have and automatic ones in stock. The ignition switch I have I believe is for an automatic. My car was originally an auto but was swapped out for a 5 speed.
Secondly, there's one random loose red wire under there. I believe it was loose earlier, because I don't remember unhooking it from anything. There's one purple wire just like it that goes to something, and a similiar green one. The red one however, I can't figure out where it goes. It's just a small, 12 gage or so wire with a small connector on the end, not a huge 10 or 12 prong one or anything. Anyone know what this is and where it goes or if I should even bother? Could it be causing my no-start issue? If you'd like I can get a picture of it. Or could it be the fact that I might have gotten the wrong type of ignition switch? What's the difference?
-Thanks, Brandon
EDIT: The red wire says "PED 6" on it if that matters.
Old Sep 16, 2006 | 08:46 AM
'86 350's Avatar
Car: '86 Camaro SC
Allright, what the ****. this is ridiculous. I've tried replacing it with an automatic one, and still no ****en luck. Anyone know what the hell the problem is? Nothing seems to be working, could it be something other then the ignition switch? Could it be that red wire I mentioned or something?
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
