lockup converter switch?
Old Sep 16, 2006 | 01:48 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i've heard you can put a switch on the lockup on the converter, i have a 1989 firebird formula 350 TPI, with a 700-R4 tranny, and i think its locking up at the wrong times...... ill be cruising, then ill let go of the gas, and i will feel a DRAG, and the rpm's will lower, then it will go away, and the rpm's will raise again...... it is especially noticeable on the highway...... i just rebuild my tranny, so i'm NOT taking it apart again
do you guys think this is the sudden drag i'm feeling is the lockup converter locking up when its not supposed to then disengaging? if so, HOW do i put it on a switch so i can lock it up when i want to???
Old Sep 16, 2006 | 03:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like it's just slow to unlock.
Old Sep 16, 2006 | 05:52 PM
bigchief's Avatar
nevermind, the converter i got is the summit 1900 stall and it DOES have a lockup in it
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
