No Spark.
Old Sep 22, 2006 | 03:12 PM
1slowss's Avatar
No Spark.
I'm having a little trouble with my 91 TPI Z28. I had the engine extensivly modifyed by a local performance shop. Because of a too busy work schedule I had the speed shop do the installation as well as the engine build-up. Everything was great for about 12,000 miles, then the engine started to run very rough. It was burning coolant. I removed the engine, replaced the head gaskets and a damaged oil pan. I reinstalled the engine and now there is no spark. There is no spark at the plugs so I replaced the distributer module. Nothing. I pulled the coil wire and there is no arcing when I crank the engine. My question is, how do I trouble shoot this ignition problem?
Old Sep 23, 2006 | 06:27 PM
1slowss's Avatar
Ok I have been working on it all day today and still nothing. I have replace the Coil, Module and still nothing. I am getting 12v into the coil and nothing out. What should I do next?
MM2Robinson
Oct 1, 2017 09:16 AM
justin57
Aug 20, 2015 07:05 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Grumpy
16
Feb 11, 2002 05:20 PM
Bort62
Dec 10, 2001 06:01 PM
