rear light panel gremlin
Old Sep 26, 2006 | 08:24 PM
lwrdr2's Avatar
Car: 1984 T/A,
Engine: 5.0 H/O
Transmission: Auto 4spd
Hey got a problem with the rear lights. When putting brakes on. Only the left side works. But you get reg lights all the way across. WHen you put the right turn signal on he lights stay bright for couple sec then slowly flash in 5 sec intervals and the backup light are on at he same time. Any ideas? Turn sig relay? bad ground?
thanks
Old Sep 26, 2006 | 09:11 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
From looking at the schematics, my educated guess would be bad ground for the right tail lights in conjunction with a blown turn signal fuse. But I might be wrong, of course.
Lou
Old Sep 26, 2006 | 09:36 PM
lwrdr2's Avatar
Car: 1984 T/A,
Engine: 5.0 H/O
thanks. Imgonna look more tomorrow in daylight. not a lot of light in the garage. Any idea on where the ground would be for it? I dont know abotu the fuse cuz if the fuse went I would think that the lights wouldnt work at all? but then again i could be wrong
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
