Rear Defroster ...New problems
Old Oct 3, 2006 | 06:53 PM
Chopper_86's Avatar
Car: '82 Trans Am; '85 Camaro
Engine: 350 cid; 2.5 mini 6
Transmission: TH 350
Axle/Gears: Posi Richmond 3.73
I did a search and went through all the threads and haven't seen this issue.
To start, I have a 1985 Camaro (base) that I got for my 16 yr old son to learn to drive. The car has been sitting inside for the past 7 years. The interior was gutted when I got the car. The 2.8 liter motor has a fresh and complete rebuild and the $200.00 price tag was perfect.
I just finished getting the car back together this past weekend and it is ready for inspection. The last remaining issue is the rear defroster is not working. I press the switch and the light comes on but when I remove my finger, the light turns off immediately. Also, while the switch is pushed, the lights dim and the engine wants to stall. It is like there is a very heavy load on the charging system.
There is power at the red wire at the switch at all time. When the switch is pushed, there is power at the purple wire until I release my finger. I check for any opens or shorts with a multi-meter fron the switch (purple wire) to the right side hatch strut and it reads 0 ohms. The ground is good on the right side.
Would this indicate that the switch itself is faulty?
It appears that the relay and timer are built into the switch...
Thanks in advance for any help that you all can give
Old Oct 9, 2006 | 10:56 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
It sounds like the purple wire has a short to ground somewhere..
customblackbird
Aug 15, 2021 10:16 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
