hatch light problem
Old Oct 6, 2006 | 01:42 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
hatch light problem
i switched the blubs checked the fuses labeled lid and tail and nothing the hatch light will not work! its a 92 z28 and it is killing me
Old Oct 7, 2006 | 07:32 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Have you checked for 12VDC to the switch?You could have a bad hatch light switch or a bad ground.
Old Oct 7, 2006 | 11:09 AM
Axle/Gears: G92
were is that?
Old Oct 7, 2006 | 12:24 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
A 1992 doesn't have a manual hatch light switch. Those were used through 1989 only. Check that you have power at the red with white-stripe wire. The light is turned on/off by the striker-sensing switch which is next to the latch. If you have power at the red/white stripe wire then the striker-sensing switch may the problem. I sell them on my web site.
Lon Salgren
Old Oct 7, 2006 | 05:33 PM
Axle/Gears: G92
were is the wire running to? how do you tell if it has power
Old Oct 7, 2006 | 06:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Buy a multimeter and hook up the red lead to that wire (+) and hold the black (-) lead to any bare metal on your frame.
Old Oct 7, 2006 | 06:53 PM
Axle/Gears: G92
were can i get one? how much do they cost?
Old Oct 8, 2006 | 12:30 AM
lonsal's Avatar
Many places. For example Harbor Freight or Radio Shack. I prefer the pocket multimeter Model: 22-820 from Radio Shack. Even a test light would do.
Lon
Old Oct 8, 2006 | 10:18 AM
Axle/Gears: G92
ok thank you i will check in to this.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
