Wiring fuel boost pump
Old Oct 8, 2006 | 03:45 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Would I be able to wire my fuel booster pump for my supercharger in with the factory fuel pump at the relay? If not is there another place in the engine bay I could wire it instead of going through the firewall to the fuse panel? I also have to wire up a pump for a methanol boost cooler. Just looking for suggestions. Thanks.
Old Oct 8, 2006 | 08:26 AM
AC's Avatar
AC
Car: Used to drive a camaro
Batass, can I ask which booster pump your using? I can take a look at my Procharger pump and see how I wired it. My setup is piggy backed of the stock pump relay and the power wire runs up to my alternator I think. Again, I can check and get back to you. I'd think most if not all of those inline booster pumps would be wired the same.
Old Oct 8, 2006 | 08:49 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
It came with the vortech. Its just a ground and power wire. If I can use the stock pump relay, can you tell me where it is?
Old Oct 8, 2006 | 09:01 AM
AC's Avatar
AC
Batass, sounds a little different as mine. The pump relay should be above the rear end (assuming your on your back looking up at the car). It's mounted outside the car on the rear well wall almost centered. Now I know why I take so many digital pix of my project. I've circled the pump relay I piggybacked to.
Old Oct 28, 2006 | 05:15 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
so you piggybacked the ground? Where did you hook it up exactly? Thanks!
Old Oct 28, 2006 | 05:35 PM
AC's Avatar
AC
Batass, I'll dig up my ATI instructions so you get it without any "loss of interperatation".
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92projectcamaro
Aug 6, 2015 01:20 PM
