Wattage to bypass VATS
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
Is the resistance the wattage running in those vats wire or what would it be. The sales rep at the electronics store said she needed the wattage. Thanks
Car: 88 Camaro
Engine: L98 350
I used a standard small 1/2 watt resistor. You'll need to know the resistance which you would get from the original key. Just measure with an Ohm meter.
Car: 91 Chevrolet Camaro RS
Engine: 3.1L V6
Transmission: 700r4 Auto
Axle/Gears: 3.23 (stock)
Did you have any luck in this? I am preparing to do the same project and was lucky to find this forum regarding the wattage. I am going to attempt this tonight.
Car: 90' Camaro RS
Engine: 3.1
Transmission: 4l60
Well the two wires were already cut. I measured the wires up and gots about a 400 reading. I'm getting the resisstor tomorro. I'lll let you guys know what happenes.
