ENGINE WON'T START
Old Oct 11, 2006 | 05:46 PM
ResonateEcho's Avatar
Car: 91 Chevrolet Camaro RS
Engine: 3.1L V6
Transmission: 700r4 Auto
Axle/Gears: 3.23 (stock)
ENGINE WON'T START
The strangest thing happened the other day... I went out to my car and tried to start my car (it usually fires right up with no hesitation), this time the starter went for a while. I stopped and tried again, but the engine would not fire. Just when I was about to give up, I tried one last time and the engine fired up. Although I was worried, I went ahead and drove it to work. At lunch I tried to start it again and there was nothing. No click, no starter, nothing! The battery was fully charged, all the interior accessories were working, etc.
At first I thought the problem could be my alarm malfunctioning (starter kill)? I disconnected it and rewired everything back to stock, but had no effect. I had my uncle (a good mechanic) come over and take a look. We installed a new ignition switch, with no luck, then he proceeded to disconnect some wiring under the dash and bypass the ignition, in which he was able to get the starter going again, but the engine would not fire (as before).
We checked everything... Fuel pressure, coil, distributor cap, we are getting spark to the plugs when the engine is turning over, etc.
Anyone have any suggestions? I’m at a complete loss.
Old Oct 11, 2006 | 05:57 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
If you bypass the VATS the Computer will not fire the injectors.
My car wouldn't start and I waited 5 min. or so and then it would start. After 4 or 5 bouts of this i found info on this forum and disconnected the the Wires from the Computer to the ignition switch and soldered in a couple of resistors to match my Keys and no more problem.
Old Oct 11, 2006 | 06:06 PM
Engine: 3.1L V6
Thanks for the info. I don't mean to be a pain, but is there any way I can get more information on this procedure? I would need to know more about what type of resisters to use and where exactly to put them. =)
Or better yet, is there another way to fix this? What was causing the problem that you bypassed? Is it something that can be replaced to make it function correctly?
Much appreciated.
Old Oct 15, 2006 | 08:37 PM
phtech's Avatar
Car: 1987 Formula/ 1990 Firebird
Engine: 5.0 Vin F/ 3.1 Vin T
Transmission: 700R4 in both
Axle/Gears: Haven't checked
Are your injectors pulsing during the no-start condition?
Old Oct 15, 2006 | 09:51 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Much appreciated.
I think the reason for my problem the key wasn't making proper contact with ithe ignition switch. It would always start eventually but I had to wait 3-5 minutes between attempts. I suppose I could have replaced the switch again but it expensive and I just installed a very alarm and it disables the igniton switch already.
Good Luck
Old Oct 16, 2006 | 12:10 AM
Jza's Avatar
Jza
Measure the resistance of the pellet on your key and buy a resistor of the value closest to it.
Instead of band-aid'ing it like that though, I would suggest trying to solve the problem.
Check the starter-enable relay, it's underneath the lefthand kickpanel usually buried underneath a mess of tar-like goo.
Old Oct 23, 2006 | 04:28 PM
Engine: 3.1L V6
I just wanted to post and let everyone know that the problem was indeed the VATS system. I performed the bypass using a resistor and it worked like a charm.
Thanks to all who were involved to help with this project, and the ones responsible for creating and maintaining ThirdGen.org. I would have been in some serious trouble without it.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
