Need some electrical help...
Old Oct 19, 2006 | 01:18 PM
dp149's Avatar
82 TA. LG4 Manual trans. Have (2) problems.
1) wipers blow fuse once turning on.
2) no parking lights. front / rear or side. Have headlights and backup / stop lights.
took dash panel down and found these (2) items. One is a brown wire (left of pic dangling near fuse box). Where does this go? It is all brown. Nothing else on insulation. Also what is 2 prong device dangling down on the right of pic?
Any help would be appreciated.
Dean
Old Oct 19, 2006 | 04:42 PM
dp149's Avatar
**Update** I also noticed a white wire that was cut as well. So I have a brown and white wire that were cut, dangling from under the steering column and not parking / dash lights.
Were does this brown wire and white wire go? I don't see another brown or white wire cut anywhere.
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
hey we"ve all got our electrical problems right? i have no idea what the brown wire goes to, but the connector on the right is part of the cruise circuit. it connects to the switch for the brake pedal to turn off the CC.
Old Oct 19, 2006 | 04:51 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
The brown wire may go to the clutch start switch on the clutch pedal. Check that first. The lights not working may be a blown fuse or fusible link or a bad ground. Get a wiring diagram from the autozone web site and check for power to the lights.
</title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>"); newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>"); newWindow.document.writeln("<br/>"); newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright © 2002 Delmar, All Rights Reserved.</font></div></body>"); newWindow.document.writeln("</html>"); newWindow.focus(); newWindow.document.close(); newWindow.print(); } function pop_norm(pc, tpe, sze) { newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120"); newWindow.document.writeln("<html><head><title>
Old Oct 19, 2006 | 05:23 PM
dp149's Avatar
Thanks for your reply. Fuses are good for the parking lights / taillights. Car starts but maybe the brown wire was redone somehow.
Man, if I can just get the parking lights and side markers to work, I am all there and can get the car on the road. So Close!
Old Oct 19, 2006 | 06:01 PM
dp149's Avatar
Ok..got the wiring diagram from autozone. found the brown and white wires. One question...what is an ISOLATION RELAY? It shows the white wire going to an isolation relay. What is this and where is it located?
Thanks,
Old Oct 19, 2006 | 06:02 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
have you checked the parking light part of the switch? maybe the headlight part of the switch dosnt turn on the side lights. i have a similar problem i cant turn on just the parking lights, and its the parking light side of the switch. so its something to look at. good luck
SRKLEGIN
Oct 29, 2015 06:38 PM
Zane Story
Oct 8, 2015 12:40 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
R13_Braz
Sep 18, 2015 05:00 PM
