Where to wire fuel boost pump
Old Oct 25, 2006 | 03:26 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im running a carbureted motor in place of a tbi and am hooking up a supercharger. I just installed the fuel booster pump and am not sure where to wire it. Is it ok to have it on all the time? I dont believe the in tank pump runs all the time or does it? Is there a way for the boost pump to only run when the in tank pump kicks on, like hooking it up to the relay next to the gas tank? Will this provide enough power? It just seems bad to have the booster running all the time pushing all that unused fuel back to the tank, and since they are efi pumps and im only using a carb, thats a lot of fuel!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92projectcamaro
Aug 6, 2015 01:20 PM
