Wont start..HELP!
Old Oct 25, 2006 | 01:47 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Wont start..HELP!
Ok so i just put a new starter in my car because the other one was making the grinding sound like it was gone. I used a battery from my friends car and I got the car started the other day. I had to fix the timing of my camshaft so off came the cover and I fixed the timing. I have those gears instead of a timing chain. Now I went to go start it and it makes the grinding sound again. Can someone help?
Old Oct 26, 2006 | 05:34 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Couple of things with starter noise...
Were there any shims left over from the starter replacement? It may be a matter of getting the starter gear lined up with the flywheel - could take some playing around.
An intermittent starter noise could be a bad spot on the flywheel. Remove the flywheel cover and inspect all the teeth.
Good Luck,
Corky
Old Oct 26, 2006 | 09:26 PM
Engine: 406sbc
Transmission: TH400
The flywheel is fine, I know this because it does turn and everything and none of the teeth look chewed up. I think it may be the shims because I used the shims from the other starter when I installed this one. I was told to take the shims out because I might not need them and it could be messing with it.
