New heated O2 sensor kills car
Old Nov 3, 2006 | 05:31 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
I recently switched from a single wire to a three wire heated oxygen sensor since I got headers. I've got the power wire hooked up to the wire going to the fuel pump fuse as I understand it is only supposed to be hot when the car is on. I'm not so sure this is true anymore since I've had this thing in my battery has been going dead on me. I've had the battery and alternator tested so I know it is no fault of theirs. What did I mess up???
Just to prove that it wasn't anything else and was just coincidence I removed all the fuses in the car one by one and tested the amp draw from the battery by having a multimeter inline between the disconnected positive wire and the battery. It didn't stop drawing until I removed the fuse for the fuel pump, and to be doubly sure it was the O2 sensor I disconnected it and reconnected the fuse and it was no longer drawing.
Old Nov 3, 2006 | 05:53 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Put a test light on the wire / fuse under the hood that you think is the fuel pump. The power should be KEYED as-in when the key is shut off it will not have power.
Old Nov 3, 2006 | 06:04 PM
Jza's Avatar
Jza
If you're feeling frisky and want to do this right, here is a wiring method we came up with years ago (credits Vader for the diagram) that will run the sensor heating element based on the car being in open/closed loop.
Old Nov 3, 2006 | 10:58 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
I'm not sure if the diagram will work since I have the EBL and the pinout is slightly different and the EVAP is no longer used.
Old Nov 4, 2006 | 02:28 AM
Jza's Avatar
Jza
lol I didn't even pay attention to the vehicle you were referring to. The point of that method was to have it to where the sensor was only heating in open-loop mode. I didn't use that pin, I used the wire from the AIR divert solenoid. When the vehicle is in closed-loop mode, air is being sent to the catalytic converter. So I keyed off of that wire.
Old Nov 8, 2006 | 07:28 PM
b_the_j's Avatar
Car: 92 RS
check this out
https://www.thirdgen.org/forums/elec...ghlight=heated
let me know what you think of my work
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
85 Jimmy
Sep 30, 2015 07:56 AM
mfp189
Sep 27, 2015 09:25 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
