fog light question
Old Nov 8, 2006 | 05:26 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
fog light question
ok people.. i got a nasty one here
i got a 92 ta... and wellmy fogs are not working. if i change the fuse when they work, but for like 2 minutes, then the fuse blows and its all done. i know there is a grounded wire somewhere... but i can find it.. and i dont really want to redo my electrical for that.. any help.. i dont know who to read wireing diagrams so i SOL there
is there any way i could check the location of this wire etc
Old Nov 9, 2006 | 07:43 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Try removing the fog light housing and check the wiring from the bulb to the connector and that the clip holding the bulb to the housing is tight. This clip has to be tight as it is what makes the ground connection (GM really outdid themselves with this design).
Old Nov 9, 2006 | 11:05 AM
dave-92gta's Avatar
yea i check one side, but gave up. i dont really know to much about elcrtical and im sort of scared to get started and fixing it. il check both sides, and grounds. but i dont think thats the problem, like they truen on but fi i hit a bump they will blow the fuse, i dunno if its the ground doing that, i think its a wire goign to or from the lights that is striped or crimped etc
Old Nov 9, 2006 | 11:37 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
If it blows the fuse when you hit a bump it very well could be a loose bulb in the housing. Check both sides since they share the same "hot" wire.
Like I tried to say before, the ground is actually the collar of the bulb and the housing. There isn't a separate ground wire running to the lights.
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
