Tachometer Problem
Old Nov 9, 2006 | 12:31 PM
kgoodrich's Avatar
Tachometer Problem
I have an 89 Iroc that is having problems with the Tachometer. Not to long ago I blew a head gasket and had to replace them. Every since then my tach is reading about 1000 RPM higher than what the engine is actually running. Anybody have any ideas what could be causing that???????
Thanks,
Kendal
Old Nov 9, 2006 | 01:11 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Might be a silly question but, did the engine ground strap get put back on?
Old Nov 9, 2006 | 01:21 PM
kgoodrich's Avatar
Yes, I actually have 2 ground straps from the engine to body & engine to frame.
Old Nov 11, 2006 | 05:49 PM
vetran's Avatar
Capacitor
Does it have a Capacitor in line from the conection of the distrib. to your wiring
Old Nov 13, 2006 | 10:41 AM
kgoodrich's Avatar
No capacitor. This vehicle has an ignition module in the distributor that has two plugs which connect to the vehicles wiring harness. It also has a seperate coil that connects to the distributor via a coil wire.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
