Weatherpack Pin Remover?
Old Nov 9, 2006 | 02:27 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I snapped off the lock tab on my IACV connecter from my harness, and I found that you could order them from TPI Parts, but I don't want to splice into the wires, as the wires are fine, and if I don't have to introduce resistance and a corrosion point, I don't want to. What kind of tool would I use to take the pins out, so I could just slide them in to the new plastic piece? I tried searching for pin remover and pin removal, but didn't find anything.
Old Nov 9, 2006 | 03:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's usually called a pin extractor. A better-stocked parts store would probably have one somewhere. Lisle makes one that I know of for sure, probably K-D does too, as well as maybe Snap-On, Matco, etc.
In a pinch you could probably improvise something with a piece of thin walled brass tubing from a hobby shop, or a rolled up business card, or who knows what else.
Old Nov 9, 2006 | 08:47 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
The keeper on a weatherpack is simply a metal tab.Just look down the barrel to locate it and push it down with a paperclip.The pin will then pull out.
Old Nov 11, 2006 | 05:07 PM
Jza's Avatar
Jza
I believe the pins on that particular connector has two tabs that have to be simultaneously flattened to remove the pin.
I used a Terminal Tool Kit from Blue-Point. It had the tool (basically a small tube with a fancy handle).
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
