ok i just finished doing a tbi to stealth ram swap. I got a harness from a 92 z-28 my car is a 92 rs. I installed the 730 ecm everything plugged right up to my under dash harness im showing feedback from all my sensors so i know that part of it is right i just have no power to the purple wire for my selonoid.
I have done continuity tests from purple wire to neutral safety switch and the green wires from the neutal to the vats module and acrossed the neutral switch all tested good.So i went in deeper and tested from the yellow wire coming off the ignition switch to the purple wire goin to the starter and that tested good when i put the key in the start position that tested good.All my dash lights come on light they are suposed to the only other thing i've noticed is for some reason i dont have any brake lights now.All the power cables are hooked up and i have power to the to red wires goin into the bulkhead at the firewall.There is one pink lookin wire that has no power to it and i cant seem to find it on any diagrams so if anyone has any ideas please let me know
