firebird odometer fix ??? electronic
Old Nov 18, 2006 | 10:12 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
what would cause my odometer & trip odometer not to work yet my speedometer works fine
Old Nov 18, 2006 | 01:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
take the guage pod out and see of the little motor that drives things is shot or has stripped teeth on the gears. might be it, might not be
Old May 30, 2007 | 02:56 PM
Jproz1167's Avatar
Re: firebird odometer fix ??? electronic
Though I would update this since I finally got around to fixing the problem.
I wasn't the electric motor that drives the odometer. It was the gear that the electric motor drives was siezed. The fix is easy I just bought a 85mph speedometer and swapped the odometer/trip odometer cluster on the back of the speedometer and now it works perfectly. after the cluster is out takes about a 1/2 hour to replace the odometer cluster.
why did I swap before I am bashed for not just putting the whole speedometer in ... well mine has a 140mph speedo is all and to buy another they get expensive is all, costed me 10 bucks to fix mine.
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
evan555222
Aug 22, 2015 07:14 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
kyle5647
Aug 7, 2015 03:08 PM
