Removing harness
Old Nov 21, 2006 | 09:36 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
Removing harness
If i were to removed the majority of the engine harness except for sensors ang ground wires and ran an non emissions vaccum controled car, would the guages still work? and would i be able to use the turn key ignition?
How Much of the wiring can i remove if any?
Old Nov 22, 2006 | 09:18 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
its been a while but it think i remember taking out the whole harness that goes into the pass side with the computer. the fuel and batt. gauges were the only things that worked. but i never tried hooking up the other stock gauges to the new engine. i got aftermarket tach, oil, and temp.
what carb and ign setup do you have. i guess i assumed they where not stock.
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
fbirdroller
Sep 2, 2015 10:27 PM
stalkier
Aug 21, 2015 01:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
