Weird oil pressure gauge problem
Old Dec 2, 2006 | 11:04 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ok guys, after my car is warm, and I stop at a red light, my gaige used to drop to zero..(Even tho I never beleived it) No when the car is hot, and I stop at a redlight the gauge goes CRAZY, spins around (All the way) bounces, jumps, and I mean like crazy...When it is put in neutral it acts normal...Keeps fine pressure while im driving...The motor runs just fine, quite and all so I do beleive it has pressure even tho the gauge says not....Any ideas.???? Bad sending unit, bad wiring, or bad gauge....On another note from time to time my Voltage gauge goes way down, but my digital monitor on my 1,5 farad cap in the back says it never goes under 14 volts, so there my be some dash connection issues..Please help, Thanks Tom....
Would'nt really want to damage my engine 135000 miles, 305 TBI V-8
Old Dec 4, 2006 | 09:41 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
It sounds like the oil pressure sending unit. My gauge started showing less and less until it showed zero and a new sending unit fixed that.
Get under the car, pull the sending unit connector and check for oil. If oil is coming out of the sensor, it's bad.
Lou
Old Dec 4, 2006 | 07:17 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
OK, last year, my oil pressure guage would read the EXACT same thing, it would also bounce around and do crazy stuff, drop to 0 at a stoplight, just as you said. So I then decided to get the sending unit fixed, my motor was quiet as can be. WELL, I just so happen to check my oil level one day and I couldnt see a drop of oil on my dipstick.......I fill it back up. start the car, everything seemed fine.
Next morning I start the car up, and Woosh...blue smoke out the back in a big cloud. Turns out, my valve guide seats and seals got toasted..
All of this relates because I thought it was a bad sending unit, turned out to be no oil in the motor, im actually surprised I didnt lock the sucker up, I recently had my motor totally rebuilt top to bottom...all for performance
Anyway, make sure there's oil in the tank Dont go through what I did.
Old Dec 11, 2006 | 06:24 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Just wanted to let everyone know, A new sending unit cleared the problem up...I was just fixxing to call a Preist, cuz I swear my car was possesed....Tom
Old Dec 11, 2006 | 06:29 PM
BigBadLou's Avatar
Engine: TPI
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
