Headlight Motor Wiring
Old Dec 12, 2006 | 11:12 PM
chevelleman_04's Avatar
I have a 87 Trans Am and my wiring up front for the headlight motors the connector is cut off and they are cut off on the motor. The wires coming from the Headlight switch has only two wires on both sides. Drivers side is Gray/white and Green/white and the passenger is gray and white, but the both the motors have 3 wires coming out of it, gray, green, and blue. How would I go about wiring them up? Thank you
Old Dec 12, 2006 | 11:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
3-wires = wrong motor for your car. 2-wires = correct motor for your car. You don't wire it up, to correct this situation you need to replace it with the correct motor.
Lon
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
