bigggg problem
Old Dec 13, 2006 | 09:19 PM
soundmaster4023's Avatar
Car: 1985 camaro Z28 Iroc-Z
Engine: 305 , 5.0 v-8 you know....
Transmission: automatic.... ugh
Axle/Gears: lol somthing i havent learned yet..
bigggg problem
ok well when im accellerating my car is almost jumping... its really really hessetatin... and sometimes when i close the hood my engine stops.... my check engine light has been on... i checked the codes i got code 12 and code 34..... im new at all this... so im extreamly lost...
fyi--- when i was putting in my new altornator one of the wires on the conector one the back of the altorntor was not cut but kina open... ooops....
zach
Old Dec 14, 2006 | 05:35 AM
voodoochikin04's Avatar
Car: 87 pontiac fiero
Engine: 2.5 liter
Transmission: 5speed
Axle/Gears: dont care.
it is possible that maybe your grounding out.. so when you give it gas something moves and grounds out, same for when shutting your hood. it would be kinda obvious to me that if i hooked up my alternator with faulty wires that a problem may occur... but thats me...lol
Old Dec 14, 2006 | 06:52 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Code 12 is the diagnostic code. It also means that no reference pulses are being detected by the ecm. If this is the only code being displayed by the ecm, you are being told that the ecm is functioning properly.
Code 34 indicates a faulty maf or map sensor. The typical problems are usually false air, vacuum leaks, or residue build up on the maf element or behind the throttle plates. Check the wiring and connectors very carefully. This code is set when the ecm sees a indicated low air flow, or unrealistic high manifold pressure. Usually a bad map sensor is at fault, but check the wiring and connectors for shorts.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
