fuse keeps blowing
Old Dec 16, 2006 | 06:48 PM
bbq014's Avatar
Car: '88 IROC
Axle/Gears: 9", Locker, 4.10's
fuse keeps blowing
The fuse for my hazzards and brake light keeps blowing! I changed it three times and it kept blowing. I'm suspecting a short somewhere... anyone have any ideas as to what may be wrong or if it's happened to anyone at all?
Old Dec 19, 2006 | 09:39 AM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
sounds like ground
If your putting the fuse in and it blows right away, the power wire is probably grounding out somewhere. this happened on my wiper fuse, it was grounding right where the hood release is behind that plastic kick panel because there is a bundle of wires that makes a shard turn right against metal and it chaffed right through. Its worth a look...
Old Dec 19, 2006 | 09:52 AM
kaptinkafeen's Avatar
Check all the bulbs - front and rear. I had the same problem and it turned out to be a rusty front turn signal bulb socket that still worked. The thing that made me check it out was the fact that the bulb seemed dim compared to the other side... go figure! Changed the buld and all my problems magically disappeared.
-Andrew
Old Dec 20, 2006 | 01:52 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
trouble shoot it by pulling one bulb at a time until the problem goes away. When it doesnt blow the fuse you will have the right wire. Check the length of the wire for any spots where it could ground and tape...
POZ
Old Dec 20, 2006 | 03:52 PM
bbq014's Avatar
Car: '88 IROC
thanks guys once i get some time off from work im gonna give it a try.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
