How do you ground a wire?
Old Dec 19, 2006 | 10:21 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
OK, I'll be honest, I know almost nothing about electricity, but I know to continue to learn about my car I will have to know about electricity. I've been searching the web, but still can't find out how to ground a wire, can anyone tell me?
Old Dec 19, 2006 | 10:24 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
to connect a wire to ground, simply scrape a section of the body down to bare metal and connect a wire. The whole chassis is grounded. Beware that some grounds which are close to the ignition system grounds are "noisy" and will cause problems with stereo equipment.
Old Dec 19, 2006 | 10:30 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
As stated before the whole chasis is a ground, if you need a direct ground I would run a wire from the ground post or terminal of the battery.
Old Dec 20, 2006 | 01:42 AM
Jza's Avatar
Jza
Best way to ground a wire is to crimp a ring terminal onto the wire to be grounded. Find a place to ground it (a metal surface that is connected to the chassis of the car) and drill a small hole there. Use a small sheetmetal screw with a star-washer and screw down the wire's ring terminal to your chosen spot. The star washer has teeth that help it "dig" into the metal and make a good connection, and keeps it from backing itself out.
Old Dec 20, 2006 | 06:13 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
First, What are you trying to do? Hooking up a stereo, amps, lights?
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
djmarch
Aug 19, 2015 12:07 PM
