fuel pump?
Old Jan 2, 2007 | 05:24 PM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
fuel pump?
on my 91 bird, 305 tbi it wont fire now. i had put the car away a month or more ago, and i went to just fire it up recently and nothing, it ran fine when put it, but i left it with very low gas. It runs if you dump a little gas down the throttle body. when i turn on the car i dont hear the pump at all. could the line be frozen or pump be frozen? or cold the pump just could of went out on it? how can i tell for sure before i rip it all apart. thanks
Old Jan 3, 2007 | 06:33 PM
Pontiackid's Avatar
Car: trans am ws6
also before i put the car away, my oil pressure gage would be really low, even when flooring it. anyone know about this??
Old Jan 3, 2007 | 06:48 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
When mine did that it was the fuel pump. Apparently if you try to start our cars when there out of gas it doesn't take too long before the pump burns out.
Old Jan 3, 2007 | 07:19 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Check for power to the fuel pump connector, if you are getting power to the pump but it still does not run then there is little else it can be. Make sure you have gas.
The in tank pumps use the fuel to keep them cool, there is a wrapper around them that soaks up some fuel to keep them cool when you are low. If you run them too long on empty, it can and frequently will burn them up. Plugged filters make them run hotter than usual and will shorten their life as well.
Old Jan 3, 2007 | 09:03 PM
Pontiackid's Avatar
Car: trans am ws6
alright, well i had put 3 gallons in though. another possibility is a mouse could've chewed the wire/s. could it possibly be the oil sending unit that could be causing it to do this?
Old Jan 3, 2007 | 09:08 PM
Engine: 350 SBC TPI
The symptom of a bad sender is that the car dies after starting. Cranking causes the pump to run, oil pressure keeps it running.
Checking the power at the pump answers the question.
Old Jan 3, 2007 | 09:19 PM
Pontiackid's Avatar
Car: trans am ws6
it never dies. but ill have to do that this weekend, i dont have a manual though. how do i check the wires to the pump?
Old Jan 7, 2007 | 10:37 PM
Pontiackid's Avatar
Car: trans am ws6
well i did the by pass thing where u find the red wire with a connector on the passenger side. and i put the wire in it and the pump turned on, and then i tried starting it while someone put it on there and it stilll woulnt fire. anyone know what it could be now?
Old Jan 9, 2007 | 11:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Just correction.. the sender is for the gauge.
The oil pump switch is a failsafe for the fuel pump. It has zero to do with the fuel pump running unless, the relay has 'bought the farm' (died).
The oil pressure switch can be omitted from the harness and the fuel pump will run.
The fuel pump relay is switched by the ECM and stays that way as long as there is a tach signal to the ECM (read: the engine is cranking/running).
THe oil pressure switch is a very common misconception about saving the car if the oil pressure drops below 'X'psi (3-5psi is when it closes btw) or making the fuel pump run.
It, the oil pressure switch, is only there to assure the pump will keep running in the event the relay fails.
Old Jan 14, 2007 | 09:30 PM
Pontiackid's Avatar
Car: trans am ws6
well today i was working on it and i took the gas line off right by the tbi, by passed the fuel pump and fuel sprayed out. then i went and bought a new relay ( the one by teh drivers side firewall, there is two) and put that in and still no start. i also checked the fure down by the batter the 20A one and it was blown so i switched that and still no start. its also got spark and everything. what could be wrong now?
Old Jan 16, 2007 | 09:48 PM
Pontiackid's Avatar
Car: trans am ws6
anyone have a clue?
Old Jan 16, 2007 | 10:37 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Did ya change the filter?
Old Jan 17, 2007 | 01:00 AM
Gramps's Avatar
Car: 87 Camaro IROC
how old is that gas?
Old Jan 17, 2007 | 03:24 PM
Pontiackid's Avatar
Car: trans am ws6
no didnt change the filter. but the pump isnt priming when i turn the key so i dont think its that. and the gas was new, it was pretty low, and the car was sitting a month and i tried starting it. no start. so i put 5 gallons of new stuff in adn still no start.
Old Jan 17, 2007 | 05:25 PM
deadbird's Avatar
Engine: TPI 305/ v6
Have you tested the pressure ? Pushing it out the unrestricted line and building pressure are two different things.
Have someone crank the engine and observe the spray from the injectors. Or, just make sure the injectors or even pulsing (they are on a fused circuit).
The pump should be priming for 2 seconds when you turn the key to the 'run' position. You should also be able to hear the relay switching. There is no fuse for the relay (excluding the 20A under the hood which is power to the pump & ECM), the ECM controls power and ground for turning the relay on/off.
This just recently happened to a friends truck I put a TPI on. He let it sit for a period and the pump went to the the great beyond. The pump will run just fine (audibly since the tank is in the cab) and fuel will come out the schrader valve on the rail (not impressivly) but, 1-2psi at the rail doesn't do much for a TPI trying to start.
Old Jan 17, 2007 | 06:07 PM
Pontiackid's Avatar
Car: trans am ws6
alright. well it has no prime when i turn the key. only way it primes is if i jump the red wire for it. and even with it primed by hot wiring it, it still wont start. where is the relay located for the pump, is it the one by itself on the passenger side, or is it one of the two on the drivers side next to each other. yea i just had the line diconnected and it sprayed out. do i just take the air cleaner off and look down there to see if fuel spits out or what?
thanks
Old Jan 17, 2007 | 11:27 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
try reseating the ecm connections. drop the ecm and physically disconnect the ecm for few minutes and reconnect it. see if will prime then.
i had the same problem with the tbi in my 89 and the ecm was at fault.
Old Jan 18, 2007 | 03:36 PM
Pontiackid's Avatar
Car: trans am ws6
alright, where exactly is the ecm located. i need to get a manual for it.
Old Jan 18, 2007 | 07:38 PM
Car: 1988 IROC-Z
passanger side. right above where your feet would be. there should be (3) - 7 mm screws holding the plastic cover in place. once the cover is removed you will see an aluminum box with a **** load of wires attached to it. that is your ecm (engine computer).
Old Jan 21, 2007 | 09:17 PM
Pontiackid's Avatar
Car: trans am ws6
ok sounds good, i will try that this week. messed around today with it for a little bit and i had a friend try to start. i took off the air cleaner and look down the tbi and i didnt see any fuel spraying in, is that where you look?
Old Jan 21, 2007 | 09:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
Yes, you should see some fuel spraying (in pulses) at the throttle blades.
Old Jan 22, 2007 | 07:13 AM
Pontiackid's Avatar
Car: trans am ws6
well even with the pump prime jumped, i still didnt see any fuel spray in. im thinking its the fuel pump.
Old Jan 24, 2007 | 04:34 PM
Pontiackid's Avatar
Car: trans am ws6
alright well i pulled the ecm down and unplugged it for about 5 minutes. i plugged it back in and still no prime.
Old Jan 24, 2007 | 07:12 PM
Car: 1988 IROC-Z
when you turn the forward watch the ses light carfully. does it blink once before staying on solid? or does just turn right on without blinking?
Old Jan 24, 2007 | 09:09 PM
Pontiackid's Avatar
Car: trans am ws6
sorry i went down to see the light what it did, but i left the hatch open so the battery was almost dead. which light is the ses. i was getting the securty light and another red one. which one is the ses?
Old Jan 24, 2007 | 11:13 PM
Car: 1988 IROC-Z
SES = Service Engine Soon(Orange Colored Indicator). if it's not even coming on at all, and ALL the fuses have been checked then the ecm is bad.
Old Jan 25, 2007 | 07:02 AM
Pontiackid's Avatar
Car: trans am ws6
well i know right before i had put the car away. the light would come on sometimes and go off. i dont have a cat though so it could be from that. last night even though the battery was almost dead. that light wasnt coming on.i know there was a 91 or 92 firebird at the junkyard with a 305 tbi in it. would that ecm work?
Old Jan 26, 2007 | 07:21 PM
Pontiackid's Avatar
Car: trans am ws6
i got a different ecm and put it in my car and still has no prime. i also checked again and no fuel spraying out of the injectors at all. when i primed the pump fuel shot out of the hose when i disconnected it from the tbi, so could the injectors be plugged or what?
Old Jan 28, 2007 | 10:00 PM
Pontiackid's Avatar
Car: trans am ws6
im going to try putting a new fuel pump in on tuesday, so i will see what that gives me.
Old Jan 28, 2007 | 10:21 PM
Car: 1988 IROC-Z
keep us up to date. i would hook up a test light to the injector harness and see if the ecm is even pulsing the injectors.
Old Jan 29, 2007 | 02:50 PM
Pontiackid's Avatar
Car: trans am ws6
i took the plug in off the injector, and i put a light on it and had power. but with the pump primed, im getting fuel up to the injectors, but i think the pump is bad where it isnt pushing fuel through the injectors.
Old Jan 29, 2007 | 03:30 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
you will ALWAYS get power to the injectors. The ecm just pulses the ground. The pin with no power to it should pulse to ground as you crank. Verify this with a light.
Old Jan 29, 2007 | 04:47 PM
Pontiackid's Avatar
Car: trans am ws6
alrigth so when i try to crank it have a light on it?
Old Jan 30, 2007 | 09:24 PM
Pontiackid's Avatar
Car: trans am ws6
im ready to take this car to the scrap yard lol. i put a new fuel pump in it tonight and still nothing. i checked alot of stuff and here is what i came up with. i am getting power at the back of the car at the pump connection, but i am not getting power at my relay. in my manual it shows it could be a wire, or a oil pressure unit. anyone experience this? the new pump sounds ALot stronger
Old Jan 30, 2007 | 11:21 PM
DTOFMFD's Avatar
I'm in the same boat, everything is in good working order but the injectors are not pulsing. Is it true the vats will not let the motor turn over if it is bad? Some where I read the vats controls the injector pulse and the starter. good luck
Old Jan 31, 2007 | 09:35 PM
Pontiackid's Avatar
Car: trans am ws6
well i have no clue, i was reading in my book and i see on teh diagram and i saw this "Fuel pump/Oil pressure switch sender" and a guy told me it could be that and when that fails you dont get power to your fuel pump, which i am having troubles with cause of the no prime. only when its by passed i get power. how much do these cost?
Old Feb 2, 2007 | 04:23 PM
deadbird's Avatar
Engine: TPI 305/ v6
Refer to the first post I made in this thread.
If you have no power at the relay (on the lead, 12-14ga wires, in or out), you shouldn't have power at the rear, unless you're cranking the engine.
Then, while cranking, if your oil pressure switch is working, you will have power to the pump even though the relay is dead.
If you put a test light (or analog multimeter) across the wires on the injector(s), it should pulse while cranking the engine.
Have you checked your ECM fuse under the dash btw ?
Old Feb 2, 2007 | 05:19 PM
MavViper's Avatar
I wonder if perhaps your injectors are dirty or clogged. Try taking them out and cleaning the filter.
Old Feb 2, 2007 | 07:54 PM
Pontiackid's Avatar
Car: trans am ws6
where is the ecm fuse, i didnt know there was one. if i can remember right i was getting power to the back of the car when i had the key turned on, i was getting it at the middle wire.but none at the relay. i i will look at it tomorrow and write down what im getting, sorry about the confusion. thanks
Old Feb 3, 2007 | 12:11 AM
deadbird's Avatar
Engine: TPI 305/ v6
ECM fuse.. (check attached image)
I'll admit, I am a little confused as to where the power is comming from in the wire to the FP. The only branching it does is under the hood.
From the bulkhead (at firewall) to the pump, there is just one wire.
Old Feb 3, 2007 | 10:31 AM
Pontiackid's Avatar
Car: trans am ws6
thanks, ill test this out today and see before i go to work. is it a problem with the 91/92 305 tbi cars. i see alot of people that have issues with almost the same stuff i do.
Old Feb 4, 2007 | 12:44 AM
  #42
Pontiackid's Avatar
Car: trans am ws6
the ecm fuse was good. i didnt mess with it to much because its in the -'s right now. i am going to give it a few weeks when it gets warmer, and let it get off my mind cause its pissing me off.
Old Feb 4, 2007 | 10:40 AM
  #43
griff305's Avatar
i was having the same problem i changed the fuse and my injectors are pumping but it still doesnt want to run
Old Feb 17, 2007 | 04:07 PM
  #44
Pontiackid's Avatar
Car: trans am ws6
i changed the opsu today and still no prime when i turn the key. it must be a wire??
Old Jul 11, 2007 | 04:39 PM
  #45
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Re: fuel pump?
im having the same damn problem
Old Jul 11, 2007 | 04:55 PM
  #46
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: fuel pump?
are you sure it isn't the vats ,cuz that what mine did ,it cranked over and everything but the injectors wouldn't fire.i bypassed the vats and it started.
Old Jul 19, 2007 | 12:58 PM
  #47
cottons 88's Avatar
Re: fuel pump?
I have an 88 305 tbi and have the same problem.no injector pulse and no fuel pump prime.what is the vats? how do i by pass it?
Old Jul 19, 2007 | 02:42 PM
  #48
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: fuel pump?
To clear up any confusion - VATS (Vehicle Anti Theft System) disables the injectors AND starter. So if you CAN crank, it's not VATS.
And if your fuel pump doesn't run, it's not VATS either because it doesn't control the fuel pump.
So those would be unrelated problems.
Lou
Old Jul 19, 2007 | 02:49 PM
  #49
cottons 88's Avatar
Re: fuel pump?
i did not know that thanks
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
