Right Blinker doesn't blink?
Old Jan 11, 2007 | 06:32 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay. I know it must have been posted before, but the other ones varied and weren't the exact some.
So, the left blinker blinks and everything. When you switch the right blinker on, The front and rear right blinker stays solid. I can make it blink manually though by moving the turn signal up and down. I haven't replaced the bulbs or anything. I think it is something minor though. So could someone help me out please?
Old Jan 11, 2007 | 06:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check for a burned-out bulb.
Old Jan 11, 2007 | 07:03 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Where at? The blinker comes on when I flick the blinker on, It just doesn't blink.
Old Jan 11, 2007 | 10:12 PM
deadtrend1's Avatar
start off by changing the flasher (3.00 part) and checking the bulbs. Do your 4 way flashers work?
Old Jan 11, 2007 | 11:23 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, I will. I think the four way flashers work, but I will check tomarrow.
Old Jan 13, 2007 | 07:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, I just checked and the four way flashers blink and work fine. The right blinker doesn't blink though. Anyone know what it is exactly, or am I going to have to do a few things?
Old Jan 14, 2007 | 10:29 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
The flashers work but your turn signals don't right? That is a signal to you that you have a burned out bulb. Also check to see if the bulb is in the socket all of the way and that you can turn it to lock it in the socket. Since the flasher works then it has to be a bulb. Tere is nothing else it can be. Be sure to chen both front and back. I just went through this yesterday. I brought my car home from the body shop and the left turn signal was doing exactley what you said. So once I changed the front turn signat bulb everything worked just fine.
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
corey8084
Sep 17, 2015 02:56 PM
