Corrosion Removal
Old Jan 12, 2007 | 07:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Corrosion Removal
Ok electronics guru's - need help. I need to know if there is a way to remove built-up corrosion off the copper tabs and pieces inside a light housing - specifically I managed to get hold of a center console flashlight, but it's corroded inside - especially the light bulb socket. Any easy way to get rid of it? Anything I can spray on and brush with a toothbrush to clean it all up without destroying the copper contacts and such? Thanks.
Old Jan 13, 2007 | 02:53 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
For rusty iron details use rust-eater gel containing 10% phosphorous acid.
For copper details use ordinary household copper & brass polish.
Use q-tips if neccessary to apply to specific parts.
Glass-bead blasting could be considered, using low pressure, but be careful.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
sahlomonic
Sep 20, 2015 07:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
