Wipers no longer turn on, what parts could be bad?
Old Jan 14, 2007 | 02:40 AM
82firebirdse's Avatar
So it rains today, and my '82 S/E decides it doesn't want to have the wipers work anymore, at all, at any setting. They were fine the other day and then nothing today. Dead, done, gone.
It has the intermittent delay wipers. The washer fluid spray hasn't worked in some time though, but the mist control still activated the wiper arms.
From reading other posts, I've seen that it could be a fuse, the wiper motor, a ground from the motor, and even the switch within the turn signal lever stalk.
Wondering in which order I should start to look for the problem, and is there anything else in the list I may have missed?
Old Jan 14, 2007 | 04:23 AM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
can you hear the motor running.can you move them manually.need more info.
Old Jan 14, 2007 | 06:16 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I'm having nearly the same problem, and it just started this morning for me too! The electrical gremlins must like to come out when it's cold...
Out of curiosity, does your blower motor (A/C and heat) also not work?
Old Jan 15, 2007 | 08:32 AM
I can't move them manually, I don't hear anything running. AC/heat blower motor works fine, rear wiper works fine too.
Old Jan 16, 2007 | 03:25 PM
sancho's Avatar
Mine turned out to be a bad electrical ground; the ground strap from the engine block wasn't making good contact with the chassis. Perhaps try to wiggle your ground strap while the engine is running and wipers are on to see if they work?
Old Jan 22, 2007 | 01:55 PM
Just a follow up that the problem was a broken wire to the wiper motor. After it was re-spliced the wipers worked fine.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
slade5612
Aug 11, 2015 07:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
