Speedometer/mileage tach not working?
Old Jan 17, 2007 | 08:36 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
All my other gauges work fine, but my speedometer won't work & mileage tach won't "roll"? What's the problem?
Old Jan 22, 2007 | 08:42 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Transmission: Automatic
bump same prob with speedometer
Old Jan 22, 2007 | 09:30 PM
xbcrguy182x's Avatar
Id check the speedo cable first. Pull out the cluster and make sure its still attached to the speedo. If not, pop it back in.
Old Jan 23, 2007 | 05:24 AM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
mine is rolling its just "lagging"
Old Jan 23, 2007 | 07:58 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Couple things:
Do you have Cruise Control? If so, the Speedo cable goes through the Cruise Transducer (located in front of Driver side front strut tower) there could be binding in the transducer.
Also, I have had binding in the cable between the transducer and the transmission as well.
Old Jan 23, 2007 | 10:26 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
I do have Cruise control & the lever is actual broken off where it goes into the steering column. That's probably exactly what it is. Thanks for the reply!
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
