diagnostic codes
Old Jan 18, 2007 | 04:25 PM
SS Ball3r's Avatar
diagnostic codes
ok, so i read in my haynes manuak how to get te diagnostic codes off of the car. The only thing is, it doesnt tell which codes corespond to how many flashes. it only tells the main code sequence(which is 1 flash, pause, then flashes)
i see the main sequence which repeats 3 times like its supposed to. then after that code sequence i see 22 flashes together thn a pause followed by 3 flashes. what does this code mean?
even just telling me what code number it is would help because the book tells the code numbers and what they are, not the flashes though.
thanks
Old Jan 18, 2007 | 04:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Two flashes, a short pause, and then three flashes is a 23.
Old Jan 18, 2007 | 04:32 PM
SS Ball3r's Avatar
thanks
Old Jan 18, 2007 | 04:52 PM
SS Ball3r's Avatar
ok, i think i just understodd something. the first set of flashes corresponds to the first numeral and the second set to the second numeral
i.e. 2 flashes is the 2, and the 3 flashes is the 3, making 23
correct me if im wrong. Becasue if its that simple then i can figure out any other sode without asking again.
Old Jan 18, 2007 | 05:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's how it works.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
