Tachometer Sticking
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
Tachometer Sticking
I recently installed a set of reverse glow gauge overlays for my 89 GTA. It required the removal of the gauge needles. I marked the spots the needles were in and reinstalled them properly. When I re-installed the gauge cluster the tachometer will not read above 2000 rpm and sometimes gets stuck on its return to idle. Does anyone know how I can repair this problem? Thanks
Axle/Gears: 3:73
BUMP!!! PLEASE HELP ! I could really use some insight into this if anyone has had any experience with it.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Is it reading correct at idle ?
The not reading above 2k/sticking could be from pressing the needle on too tight. I did this when I put my overlays on. If press the needle back on untill it bottoms, it will rub/bind on the overlay.
Or so was the problem in my case.
Car: 91 camaro RS
Engine: Lo3
Axle/Gears: 2.73s I think
how did you get the needles off on a 91 rs man it kills me I got em in over the top of the old ones I couldnt get thew damned needkles off.
Axle/Gears: 3:73
Use an angled fork to gently pry the needles off..be sure to mark the position they were in before removing them, then install the gauge cluster in the car with the plastic lens off to make adjustments
