how bad did i mess up?
Old Jan 16, 2007 | 07:17 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I was working on my car (tpi to carb swap) when i decided to turn the ignition on to check for leaks and i forgot that the ignition power wire was disconnected and sitting on the intake so i turn the key over the pump ran shot fuel no leaks everything electricle worked then i heard some popping and crackling and smoke coming under the hood turned the key off and looked at everything and the only thing that seems to have been burned was the end of the power wire was dark from hitting the manifold. Now nothing works but headlights and interior lights pump wont prime all my gauges are not functioning turn signals wont come on wiper motors wont run nothing.
Old Jan 16, 2007 | 07:27 AM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
have you checked your fuses? you pretty much grounded out your car, you probably know that already but i would check your fuses.
Old Jan 16, 2007 | 05:34 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
fuses seem fine i think it may be a fusible link all the key on position accessorys dont work but the headlights and interior lights do
Old Jan 18, 2007 | 09:32 PM
xGR1Mx's Avatar
Check all your cables, this happened on my '73 Camaro when I was jacking it up. Some metal piece touched a wire and burned the wire just like yours, White-ish smoke went everywhere, car wouldnt start, same deal. We wrapped it with electrical tape and connected everything again. You most likely shorted a power/ignition wire, which is why your headlights still work.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
87hellbird
Sep 14, 2015 05:08 PM
